Optimum off-road-motor bike gear ratio?
dtj6ppc
61
redondo
Is there a gear ratio calculator or formula that can determine the optimal final low drive gear ratio for an off-the-road motor bike?, that will take into consideration;
-a total bike, motor, rider, and carry weight of 325 lbs
-1.6 horsepower
-7,000 max rpm
-40 percent max incline grade climb capability
-26 inch wheel diameter
-at 5mph
thanks..................Don
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
24
Ridin' inSane Diego, CA.
Hey there Don Redondo, welcome to the forum! It would help knowing what kind of gearbox you are running to determine what you're looking for gear ratio wise. Or are you trying to determine which type of gear box to use?
Please let us know....help is on the way! dnut
Side note......if you're running a 4-stroke engine, a 72 tooth rear sprocket comes too mind.
-1.6 horsepower
-7,000 max rpm
dtj6ppc
61
redondo
Hi Scotto,
Exactly, I am trying to figure out what combination of gear box, jack shaft gears, crank gear, and rear wheel gear that combined will give me a final drive ratio adequate enough to move 325 lbs up a maximum incline of 40 percent, using 1.6 horsepower, at 7,000 rpm, at say a minimum speed of 5 mph........................Don
scotto-
Jun 3, 2010
6,505
24
Well then I'd say a rear sprocket of 72-75 teeth on whatever set-up you decide on. I don't recall the cliffs at Palos Verde being much different than that of Blacks down here.....hope you're gonna use a rear rack mount for your board, unless you don't mind dings? Cheers!
