Arizona Dyno-Glide Build
tommyboy1442
244
chicago
bill, awesome amazing work. you and culver have it down. im curious I have the same frame could you make the same fuel tank for me?
Big Bill
117
arizona
Hay Velo
Where do I start, I stripped the bike for Paint and just as I finished stripping it work went nuts , been working 5-12s and a few 15 hour days just for fun.
Now that thing have calmed down I am back to the painting.
I have been lurking around the Board Track forum a lot so the next build
will a little more vintage. Speaking of vintage how are the projects going?
We will need to get together again , I still have a few thing on my plate
but give me a call if you need a hand.
OOOO how is the other project going ? Wink!! Wink!!
Big Bill
117
arizona
How you doing Truckd
Well I'm so good with computers , How do you PM ???
But I just finished priming the tank , I hope I don't drop it again
after painting the clear, the frame ,fork and engine covers are
done so that leaves the tank, intake and chain guard.
I should have it painted by next weekend then I can start
putting it back together.
Sorry camera is down.
curtisfox
6,046
3,949
minesota
Very easy just go up and left click on truckd name and it pop send a privet mesage fallow the steps and hit send or submit...............Curt
atombikes
525
Northern VA
Hi Atomic
I am using 1/2" Aluminum plate ( not bar stock ) I am working on the trans mount now, I should have pictures buy this weekend.
Bill
Bill-
Is the gap between the backside of your clutch bell and the trans plate tight? Like .060" or so? I'm thinking of re-doing my driveline using a trans plate, but am worried about the small gap. Did you have to shim your clutch any?
thanks, Ed
Big Bill
117
arizona
Bill-
thanks, Ed
I have Allen heads bolts counter sunk into the trans plate, but they
stick out about .200 with a lock washer . so I put a shim on the
crank to hold the clutch about .150 away from the Allen head bolts.
I ran it closer on my old bike but as the clutch broke in it had a
little more side play and would hit the bolts .
If I can figure out how to up load I will post some pictures, My photobucket
has changed and I can't download pictures for some reason.
Hope this helps.
Big Bill
117
arizona
Nice Job Bill ! Looks a lot different then when I saw it in Arizona
It is not as rough now. My kids think it like an old hotrod.
The bike is done and I can't load pictures
in to the computer this bites! Photobucket has changed I can't
upload my pictures , and I tried to load a picture into the form
and Photobucket has no option to let me do that any more.
If any one has any ideas let me know.
truckd
2,837
134
palmdale calif
Start a picture file on yer computer (down load the pics ) to computer and size them to fit this forums format, there is tutorial on how to post if you look at the info categories
Big Bill
117
arizona
Thanks for the help guys.
Ok now , Next is to get the pictures on to the lap top.
Todays progress, Clean all aluminum parts , grain the parts with
a red scotch bright pad and did the same with the head set and seat
post ( Crome parts ) .
The bike is all together and ready to start!! Not 1 scratch on the reassembly
and yes it took awhile.
This is a base clear coat , Red and Cream color. The tank has cream
panels on the sides ( picture later ) .
A trick my bubby told my to try on 2 tone painting was,
1. Paint the main color then 2 coats of clear.
2. Wait 24 house sand with 600 and be careful not to go through
the main color, tape edge of two tone with fine line tape then
mask the rest off with tape and paper.
3. Paint base let dry then remove masking and clear coat the whole
part.
C:\Users\Nicole Booye\Desktop\Motor Bike\105.JPG
Big Bill
117
arizona
HAHAHAHAHAHAHAHAAAA ( cough ) 49c sticker... Nice NICE work Bill! Well done.
Hey Velo
You know I just finished the kick stand and made other badge O yes
I made 1 more , And you know it has worked already so I thought
hey just I more program!! and a 2-1/4" piece of aluminum. LOL!!!!
See you at the Pav. today.
