Hi, I need to bend my muffler about an inch, so the pedal crank won't hit it. The only tools I have is a vice, and two clamps. How can I bend it? This is the last step for me to get my motor running (hopefully)
Like in the movie "Taken".....goood luck. I wouldn't think about bending without heat. How did you put the bike together with a vise and two clamps (your only tools)?. Go get a torch, heat till cherry red where you want the bend (while it in the vise) and put a pipe or the like in the hole, and bend it slowly. There are other ways like 2 door says.Hi, I need to bend my muffler about an inch, so the pedal crank won't hit it. The only tools I have is a vice, and two clamps. How can I bend it? This is the last step for me to get my motor running (hopefully)
Hey sorry I am still new to this, what do you mean oval the two mounting holes?Just 'oval' the two mounting holes so that you can swing the pipe away from the cranks!
Venice didn't use proper machinest terminology. We call it 'wallowing out' the holes...Hey sorry I am still new to this, what do you mean oval the two mounting holes?
Oh ok that's what I thought he meant. This method will still work using the stock gasket right?Venice didn't use proper machinest terminology. We call it 'wallowing out' the holes...
Just make them bigger! If a 1/4" drill will go through the holes, try a 5/16". The bigger the holes in the flange the more you'll be able to reposition the pipe/muffler. Not always but sometimes just enlargening the flange mounting holes will allow enough movement to get the clearance you need. Just use common sense. Don't go too big.
I agree, but how much filing to oval the holes are needed. If we were at the bike then we could determine just how much was needed. I have bent the pipe (with heat) at two different spots, to make room for the bike crank. I have also had to bend the crank on certain builds. And some of both.No, I actually meant to say "oval the holes". I file just the top of one hole & the bottom of the other so the pipe can be turned without making the holes too big.
