Jet size NT speed.
Gus
7
Puerto Rico
Hi to all I have a pk80 from cheezpks with NT speed carburetor I'm planning to buy new jets set. Did you know what the stock is?thanks in advance.
Gustavo.
YesImLDS
960
12
18
Columbia, Missouri
Re: Jet sise NT speed.
Stock size is normally a 70 jet. Some come with 72 as well. If you wanted to make drill your own jets you could get 61-80 drill bits for under ten bucks as well as a some solder and use your jet you already have as well.
Gus
7
Puerto Rico
Thanks I prefer to buy a set. My engine run perfect it's in anticipation to the tune pipe.
Gus
7
Puerto Rico
Well I do it. happens I have the micro drill first l check the size it was 69 .I used 68 (more big)and carefully drilled. Just one size big and the difference is badly big. Lost tork and speed. I can't believe the difference. I reopen the carburetor check and clean all and nothing happens. Next move ls to install a new one.
Gus
7
Puerto Rico
The power is back! I find a jet from regular nt I checked the size it's 70. Is one size less than the original now it's more powerful than in the beginning. So a little change do so big.
Tyler6357
1,293
294
83
Santa Barbara, CA
