i will never , ever purchase another 2 stroke engine kit again! These things are possibly the worst hunks of junk i have ever had the pleasure of owning or repairing. here are the troubles i have had with just 1 of the two i own 1) parts falling off-had to loctite everything!
2) bad plug wire-replace with aftermarket
3) Sticking float- adjust motor to allow carb to set level
4) broken stud in rear engine mount- broke off stud flush in motor, drill out stud and retap!
5) broken stud in rear engine mount again- this time i used a higher quality stud than original and it broke off flush again in the same dam spot!
6) magneto case filled with water, spent two hour with contact cleaner and pices of paper to clean the magnet!, then reseal cover with silicone!
7) bike frame brock under front engine mount- weld tube back together with extra reinforcement.
I know what you are thinkin, everything breaks eventually right!. i have only owned these two kits for less than three months, so far i have been repairing as much as enjoying them. I am building a bicycle built for two as we speak an let me tell you my briggs motor is coming out of retirement!
The other kit i own has given me no trouble so far ironically enough but i am sure it will, the dam is prolly ready to break and i will be flooded with repairs with this one too. if i ever build another two stroke machine it will be power by a chain saw motor or one of them awesome little motors designed for model planes.
