The clutch on my motor is not engaging the way it should. when I let out the clutch it doesn't start the motor but it still turns it doesn't lock the clutch in place. Can anybody help me?
Thanks but I have read that and found the problem to be either the clutch plate wasn't tight enough or the clutch pads were worn. Appreciate the comment though!
Hello, directions please for a clutch that is not working properly - the plate pin does not push out. Not sure if the problem has anything to do with the cable or not. Thanks..
