My New custom build, having issues
Chopperz
28
Victoria, BC
I honestly didnt realize it had to be clipped in a particular direction. The bottom of the U was following the chain movement. (should it have been the other way?)
Regardless, between the two breaks I no longer have any more master link clips - and will likely just order the chain Johnny recommended
crassius
4,032
158
USA
3 main reasons for snapping a chain
1) engine a bit loose and starting to lean to the left
2) rear sprocket a bit off in the up/down direction & chain tensioned at the loose spot (when it gets to the tight spot it'll snap)
3) tensioner not feeding the chain so that it is centered on the rear sprocket (making it ride up onto the tops of the teeth) - can be cause by tensioner out of line, or by sprocket being off in the left/right direction
Chopperz
28
Victoria, BC
Hey guys,
So chain issue is resolved - switched to the K910 KMC KoolChain, and have attached both ends directly (no master link), and it looks like its holding up amazingly.
However, the engine continues to cut out. I believe this is due to the fuel filter--the gas is only filling up around half way, as such the fuel isn't making to the carb consistently (if at all)
Suggestions?
Would putting in a better fuel filter be a solution?
http://www.canadiantire.ca/AST/brow...ine+Style+Universal+Fuel+Filter.jsp?locale=en
Chopperz
28
Victoria, BC
Just wanted to say thank you to everyone for your advice -- finally got the bike running brilliantly!
(I know I'm not supposed to do this on the first run) Wanted to see what the bike could do - got it up to 62km/h :D
Does anyone have any tips for getting the bike quieter? It currently sounds like a really loud dirt bike when its running
