80 cc 2 stroke
Sugga sugga
12
Fargo
I I have an 80 cc 2 stroke that is more or less my main transportation. That the clutch has gotten slow on. It will disengage quickly but takes several seckonds to engage and it dose so slowly. Please help
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
I'm not quite understanding your problem.
Are you saying the clutch slips? Does the engine rev high then seem to grab after you have released the handlebar lever?
Sugga sugga
12
Fargo
When i use the handle bar lever to pedel my bike so i can get it started and release it the cluch is slow to enge and it just kind of boggs me down rather then turning the moter quickly
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
How fast are you pedaling? You need to be doing about 10MPH before releasing the clutch lever.
Are you using a high compression cylinder head? Your symptom sounds as if the clutch is engaging but not spinning the engine. This is from the clutch slipping. Either the clutch cable is too tight or the clutch needs to be adjusted.
Here's a good tutorial for adjusting the clutch and cable.
http://motorbicycling.com/showthread.php?t=22729
