Hi all,
I have a reallllllly interesting question so lets get started.
First of all the specs:
66cc with a puch head, recut the chamber to knock compression down to 150 psi or so
Sbp pipe at approximately the beginning primary length, decoked and the fibreglass in the pipe was plugged so repacked with stainless scrub pads and re-riveted back together
Dellorto phbg 16mm carb and free breathing filter
adjustable cdi graciously built by Ivan
Intake and exhaust port have been opened up mildly, with nice radiuses in the corners.
Transfer ports have been blended nicely as well.
Intake side of piston matched to intake port.
Crank has been rebalanced for higher rpm/balance factor.
Custom intake manifold built by myself with a 16 mm through bore that mimics the stock manifold and is only perhaps 1/4''-3/8'' longer max.
It has a bung welded onto it for the barb that has the tube to a custom aluminum boost bottle.
The manifold is where problems are occurring. Last year I was running exact same setup (but using stock oem manifold)and at about 6500 rpm the bike would sorta 4 stroke then rev like a rape date up to 7800 rpm and more if I let it go, did not want to go higher for more than a brief spurt. Now I realize the pipe action may have caused this weird sorta double carburating rpm range on info provided from other forum members.
The new intake mimics the stock oem shape as I have very little space in my frame and the curve is smooth and the flange that bolts to the port is beautifully hand blended and after all was done I hit the inside with a bead blaster to keep the air fuel mixture tumbling.
After starting rich this season and working leaner 1 jet at a time the mixture is nice and tan even if you look rt down at the bottom of the porcelain in a bh7s plug.
NOW the bike does not want to rev more than 6200 rpm, lots of power and torque all the way but wont rev out. Starts easily, idles like a champ.
Anybody have any answers or areas on where to start??? This is very strange!
