Schwinn Panther 3 piece crank advice
theaceinthehole
11
San Jose
Hi, I have an old straight bar schwinn panther but it is just the frame, and I recently purchased a 7G, also known as the 4G T belt, 4 stroke kit. It came with widened crank arms, but it did not come with a bottom bracket assembly and I have no idea how wide of an axle I'm going to need for the bottom bracket. I was looking at parts on this website and maybe someone could clear some things up for me because it looks as if I have two options here.
Option 1: Spindle http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=108
Conversion kit http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=56
Option 2: Cartridge http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=107
Bottom Bracket adapters http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=104
as well as the cartridge tool for installation.
I'm assuming these 150mm+ spindles combined with widened cranks would allow for both a 4G or a EZM Q-matic drive to be used?
MotoMagz
1,817
1,154
Michigan
Option 2 is a nice wide set up that many people use. If your kit has the small bent crank arms then you should be good.
Citi-sporter
206
43
28
North Bend, Or,
There was a time not long ago that the 3 piece conversions had spindles that reused the original one piece bearing cups. I'm guessing these aren't available anymore?
