My engine has been difficult to start pretty much since I bought it. It might have started a week or two after but now it's getting really annoying.
The first problem is that sometimes I will ride down my huge driveway to start it and when I let out the clutch at the bottom it just bogs without starting. Or it will act like it wants to start but when I pull in the clutch, it will shut off instead of idling.
The second problem is that once the motor has been started it won't function properly for the first 30 seconds or so. Every time I twist the throttle the engine just bogs, even when idling. Why is this?
I have a LuckyEarlyBird eBay kit running at 100:1 with Opti-2 oil. I replaced the stock plug with an NGK iridium plug. I also moved the carb clip up a notch from the middle position. My needle has 5 notches though so there is still room to move the needle up another notch if necessary, even though my plug now looks to be about chocolate colored.
Any help or suggestions are appreciated.
