I have a question for Q-matic owners or dealers.
How much should the clutch/10T gear be able to slide on the shaft? If I remember there was just a little bit of play.
I am doing a routine cleaning/maintenance and noticed the clutch/10T gear slides completley to the other side (none drive side) of the shaft. It results in a misaligned chain and is probably the cause of my increased noise and vibration.
Is there a lock ring on that shaft to prevent this or is there a set screw that might have become loose?
I'm pretty sure it is not right. Going to pull her apart and see.
I will probably be in need of parts which I hope I can get at McMaster-Carr.
Or thru one of the q-matic dealers here.
Mark in H.B.
Mark in H.B.
