Aero motors are specially built for max power at a certain rpm depending on prop size.
They don't have to accelerate smoothly through a big rpm range like direct drive engines.
They are usually more powerful per cc than regular motors, but less flexible in running.
You can easily tune any engine for your rpm needs with a pipe and carb or porting mods so don't insist on a aero motor unless you get a good deal.
You want something as powerful as possible to pull a serious prop or your idea won't fly (snork) Chain saw would probably be the best bet for power vs, cost.
Make sure you have a SERIOUS safety cage too...high-rpm prop failures are NO JOKE!
I still think it's a bad idea, but as long as you approach it with the potential dangers in mind, it can be done safely.
