Speed not going over 22mph?
Newguy
4
Iowa
Recently I have had a problem with my motorbike, instead of going 33mph at top end, my top end has been stuck at 22mph no matter what I seem to do. I have replaced the spark plug to a NGKB6HS, I have put a new spark plug boot, Changed the carb, to a RT dax High performance carb, and still cannot find out for the life of me what is causing to to stick at that speed. I am suspecting that it is the CDI in some way but not sure.
Im really scratching my head on this one some input would be wonderful.
Newguy
4
Iowa
Not gonna lie, im very inexperienced when it comes to these motorbikes. When I look at the clutch am I going to look to see if the clutch is grabbing completely? and I've probably checked and rechecked that speedometer a billion times, its definitely reading right.
rodolfo19772002
3
miami
Hey. New guy. I. Just thought maybe. Your throttle is stuck check the cable maybe it's not going all the way. Maybe that's why u can't pick up the higher speed.
Newguy
4
Iowa
I went and took a look at the throttle, the throttle opens all the way just fine. I suppose I might mentions one time before the problem started my motorbike had back fired and I smelt what was burning wire, which is why I suspect the CDI any suggestions?
