Difficulty of replacing a crankcase body?
jeffyh
53
Madison, NJ
Soooo... I snapped the bolt head on the front engine mount and had to drill it out. I didn't have a tap and die kit, but the soft engine let me thread it using a 10.9:confused: bolt I got at home depot. Regardless I think I may have drilled too deep. I checked with a wire and it stops but it looks like fuel is slowly leaking out from the threads. Can't really think of anything else other than drilling too far that would cause it.
Is there a way that I could seal this up? If not, how difficult is it to buy one of these and rebuild my engine? Are there any special tools I'd need? I have a basic stuff like a ratchet set, torque wrenches, drills, etc but nothing like a hydraulic press. Nor have I don't anything of this sort before, but am a perpetual tinkerer and work on cars. I can manage everything except inner trans and engine block. Head's I'm okay with.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Clean any remnants of fuel with acetone or carb cleaner, and put some silicone in the hole before you re-install the bolt.
crassius
4,032
158
USA
look in the ' Mounting Techniques for Bicycle Motors' area for other ways to mount the front with angle iron and suchlike - if you find another way that will work for you, then put in a bolt to seal that hole with some serious loctite and just don't use it for mounting
jeffyh
53
Madison, NJ
Thanks, everyone. Will definitely do the silicon trick. I'm already using loctite blue, and it's getting past it.
Anyways, still wondering what the difficulty level is of rebuilding a bottom end and if any special tools are required.
crassius
4,032
158
USA
sometimes the mains will take some real work to get them off the crank
sometimes I use a wedge in the open side of crank cheeks to hold their true if the cases need serious force to mate
all in all it can be a big project
