What's Your Next Performance Project On Your Bike?
5-7HEAVEN
2,661
240
Pipe dreams or definitely on the "to do" list, let's hear about your next move.
After installing my twin engines, I want to:
1) Raise the front engine/drive assembly at will, using cable and clutch lever.
2) Install rear HD rim, 12g spokes and 16t Staton hub w/7-gear.
3) Replace rear friction drive with Staton chain drive gearbox.
4) Select Mits 43cc, 49cc pocketbike engine or 40cc Polini air-cooled engine for rear drive.
5) Install front suspension fork with disc brake and fabricate mounting bracket for friction drive. (Jeez I miss my suspension fork.)
6) Install two engine tachs and a speedometer.
Anyone else with wild dreams? It doesn't mean I'm gonna do all this, but I want to.
Spikedfox
59
well you just gave me one, i was debating weither to use one of 4 engines, But Now i can use 2, also why make a lifter cable when you could make a lifter leverthat goes along the frame under your seat
5-7HEAVEN
2,661
240
Spikedfox, I'm trying to raise the front engine. I already mounted a Happy time locking clutch lever and cable onto the handlebar. I just need to fab the lever mechanism at the drive assembly, add the springs or bungee cords and shorten the cable.
