inspectorcritic
I got a ported GT-80 66cc 4.5 HP motor I took a long trip 230 miles did ok dispite shake down repairs along the way last 30 miles power loss problems first I notice my dynamo wire fell off wrap around exhaust melted must of shorten out then the continue power loss prior I had a oil seeping out of the head I used a fabric gasket in place of the thin metal, thought it as the CDI why it was not fireing bought and tried 3 so far ohms ranging on one 6.5 ohms another 17.1 ohms the other I don't  know next I have tried 3 magnetos most are in the 304 ohms to 308 ohms none work tried 3 spark plugs Z4C and a NGK 6HS-R still no spark. on 1 magneto I put a volt meter too choatic unstable readings from 5 to 11 volts the engine putters won't pop and run pulling the plugs out there wet with gas so I got gas getting in air don't know I got  a CNC carburator prior soak the air filter in gas to get the dirt out. Compression does not feel like it use to feels weaker.Tell me Norm how do I get the damn thing to run?
