thanks kelly. hold on to it i am sure we will get togather this summer for a ride and i will get it then
What kind of speed are you guys getting with the stock Chinese 80cc kit and 44T sprocket ? I'm on a 24" bike and seem to be getting 20mph. Does a 26" make much difference ?
thanks
New to this.I know that every now and then we have a questions that isn't urgent and doesn't require a long answer just a few simple words. So here you go my first question of that type.
Okay my engine is mounted almost perfectly vertical very little tilt. But some I have noticed are at about 45 degrees or more. So does that effect the carburator. If so how.
Are you saying the main shaft turns and no piston movement??? Yikes. Are you watching it with a box end wrench?Tried it and the shaft still turn's without the gear's or piston moving.
I cannot think of anything else to do but send it back??
