I'm having trouble with my bike where it wont start. I can pedal up to about 15 mph and drop the clutch and it will only engine brake. It will occasionally fire but only once or twice. Sometimes it'll run for a few seconds. I'm calling it an electric issue because fuel and air are good and when I pull the plug I don't get spark besides one or two occasional flashes. After doing some reading I got out my old wavetek HD110.
Here are my results
CDI test
Wire-------------Expected----------Observed
Black to Blue------1150K-------------Infinite
Black to plug------2.6 K--------------7.39 K
Blue to Plug-------1150K-------------Infinite
Magneto test
Wire------------Expected------Observed
Blu to Wt--------327-----------364
Blk to Blu--------327-----------Infinite
Blk to Wt--------2.1-----------Infinite
Blk to Gnd-------0-------------0
Blu to Gnd-------327-----------Infinite
Wt to GND-------2.1-----------Infinite
I'm guessing this means both my CDI and magneto are either burnt or have bad connections? I'm leaning towards bad connections since I have a single spark occasionally. I didn't try pushing the probes through the insulation so I'll give that a try and see if anything changes but I figured it'd be good to post what I know at this point in case anyone has seen this trend before.
Thanks in advance
Here are my results
CDI test
Magneto test
Thanks in advance
