http://i999.photobucket.com/albums/af118/rohan3ni/IMG_6947.jpg
if everybody out there ave problems like i had with mines i found this fix. all i did was get a peice of metal from home depo.
Holy cow.It looks a little crude but...
It "won't connect" because your pedal chain has set the wheel distance.thats the chain i got. and i did take out some links out. if i try and make it shorter the master link wont able to connect.
clever boy....i'd only add that double nuts are in order, maybe w/ a split washer in between......you have accomplished a fix any farmer would be proud of...i like how you picked up the brake arm strap...so are their different quality tension rollers??? i'm amazed the chain doesn't just destroy the nylon roller that seems to be the same no matter the kit..... really nice fix. i do love clever fixes! charlie in baltimore
yea i use bits here and there to make up the whole thing. the only thing i had to buy wat the 4ft metal.Creative that's what its all about!! I noticed in the photo it looks like your coaster brake arm is attached to the stock piece of metal?
