So I finished my first build about 4 days ago. Since then, I've been trying to break it in a bit, get the performance levels to balance so I'd know how it was running. Problem was, I couldnt get it to idle no matter what I tried, the choke ran better than the normal, and day by day the normal was running worse and worse.
Couldnt figure it out.
Today I went in to reinforce all my connections (I'm already using high grade steel posts, so I added a 2nd strong nut to each one with lock-tite, red or blue) and I noticed that the carberator was soaked with gas. I looked around until I saw the intake gasket... and could only find a couple shred left, on the outside of both bolts. Nothing left near the intake. I replaced it with a high-heat liquid gasket and sealed it back up. Now its running stronger than it did when I first put it together, and it idles like a champ.
Is it common for the intake gasket to last less than an hour of run-time? Was this a fluke or should I just automatically replace it as soon as my kit arrives?
More importantly (rather, more immediate..) should I be concerned about the other gaskets failing? Do I need to upgrade the engine and exhaust gaskets or are those usually ok?
TheDave
Long Beach, CA
If you want to see it, I have it listed here. Forget that its an ad, it just happens to be the only place I have pictures hosted right now. (unless you're interested or want to pass it on) =)
Motorized Mtn Bike - NEW Engine 66c
TheDave
Long Beach, CA
