Old 07-30-2009, 10:11 PM
2door's Avatar
2door 2door is offline
Default Re: Worksman step through bike build
When you say a Dax engine I assume you mean a 2 stroke. With no bar to mount the tank you might want to explore putting it on a rack behind the seat. Keep in mind that it will need to be higher than the carburetor. As for the CDI, (not a magneto, it's an ignition module), you can mount it anywhere. You'll just need to lengthen the wires and spark plug lead to accomodate your choice of location. And welcome to the forum. Good luck with your build.
