Old 07-29-2009, 09:17 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
Default Re: What Do These Chinese Symbols Mean?
That is your choke, lever up is closed, lever down is open. With you motor warmed up the lever should be down. If the motor does not die with the lever up then you may have an air leak.
My buddy could never get his motor to start without using the choke, I never needed to use the choke to start mine.
