Old 07-28-2009, 07:50 AM
Sydneysider's Avatar
Sydneysider Sydneysider is offline
Default Re: Locked UP ???? Help
Originally Posted by Buzzfire View Post
So as far as the carb goes. Do I need to move the carb from the engine. I am not seeing a screw underneath that I can unscrew to drain the excess oil.
you got the older carb, newer ones have a drain screw down the bottom.. there are 2 screws you gotta undo on the float chamber to take off the bowl. When you put it back together you might need a new gasket if the older one leaks alot..
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..."
