Old 07-23-2009, 07:17 PM
perkoff perkoff is offline
Default Re: Schwinn Landmark Front Tube Size
Originally Posted by Cabinfever1977 View Post
the tab on my front fender broke(drilled out ribbet and added metal L plate and bolt)
replaced stock kickstand with a adjustable heavy duty kickstand from walmart(goes in stock location).
got a flat tire on the rear(changed intertube,keep patches and glue and airpump with you and you can slide tube out while wheel is on bike and patch and put air in,good to go)if not it will be hard to walk to home since these tires when flat come right off the rim. when i got the flat i didnt have anything and walked it 1/2mile home and tire can off rim and i had to plastic tie the tire on the rim just to get it home.
tensioner does not stay tight and wants to go into the wheel,i put the tensioner on tight and layed a bolt like this ( I----- ) behind the bottom of tensioner and added a hose clamp on each end of the bolt to hold bolt to frame and this keeps the tensioner from moving.
besides that the engine went on great.
Sounds like a good idea. Thanks.
