Old 07-20-2009, 09:24 PM
Cabinfever1977's Avatar
Default Re: Proper placement of joint binders when mounting rear sprocket
i have a coaster brake hub and the manual told me to put one rubber inside and one rubber outside,but if i did that the sprocket and bolts would hit my brake arm and stuff,so i just used rubber and metal plates on the inside of wheel and i used my second set of metal plates as spacers between the sprocket and everything clears just the rubber is thick and the sprocket wouldnt even fit over the wheel hub if i used a rubber between the sprocket and spokes. if i get a chance to take my sprocket and all those bolts out i may see if i can put it together diffrent.
for everyone else i reccomend that you use 2 rubbers with your wheel,one inside and one outside.
