Old 07-20-2009, 08:53 AM
floridaboy's Avatar
floridaboy floridaboy is offline
Default Re: Gas Cap Problems
I found out if you turn the cap up side down and raise up the rubber gasket and look around the edge you will find the little vent hole. The cap that i had used a small slit not a hole like the the cap that worked good. I took a small bit and lined up with the slit on the outside edge of the cap and drilled through the edge and into the slit and made it larger. Problem solved and no hole in the top of cap that water can get in. Ypu only see the small hole ion the edge of cap.
