Thread: crank question
Old 07-13-2009, 09:12 PM
Default Re: crank question
If you have everything removed...MAG magnet, small crank gear, and all case screws...just tap it apart with a plastic deadblow hammer. The bearings are not a press fit to the crank.
If you have not removed the clutch will need to! There are 3 case screws behind the clutch assembly.
