Old 05-02-2008, 10:04 AM
HoughMade's Avatar
HoughMade HoughMade is offline
Default Re: removing and adding chain links on motorized bicycle chain
Originally Posted by toytime View Post
Until a couple of weeks ago, I was like you Pablo, thinking that the pin end was "rounded over" or mushroomed. From what I learned the pins are not like this at all and even grinding is not needed. That is why a punch and hammer works. It seems to be a friction fit.
You are exactly right- a chain breaker is great, but a punch and hammer works fine. I never grind the end of a pin. If you do, it may not hold well if you try to reuse it....which often happens. To use a punch, just put the link up on an old small socket so the pins has somewhere to go, put the punch on the pin, and drive it out.
29/10ths cubic inches of raw power.
HoughMade at
