Old 07-06-2009, 07:52 AM
drhofferber drhofferber is offline
Default Re: more chain problems
Originally Posted by Bikeguy Joe View Post
Sounds like you may have bent a few links.
with that truck supply roller and bracket on a setup like 2door does, you have to tweak that bracket to get it lined up right...that 41 chain is going to give you some grace,but you must watch for clearance between chain and tire...also if you are using the truck supply bracket and roller, you must use a set screw on the bracket so if it moves it doesnt go all the way down....than you will have a chain problem...all in all, good idea but pay attention to application...Dennis
