Old 06-27-2009, 06:52 AM
leftywoody's Avatar
leftywoody leftywoody is offline
Default Re: bike going slower
take your air cleaner cap off and check the brass nut that holds your choke in place . Mine worked loose and the choke flap would slightly close as the engine would increase in revolutions . it will cause you to loose power . Use a little loctite on that nut . Good precaution even if it isn't the real problem .
