Old 06-24-2009, 04:47 PM
Junster's Avatar
Junster Junster is offline
Default Re: Help! After 100 miles engine wont start
You might disconnect the fuel line from the carb and put it in a glass jar. Turn on the petcock and check the flow. It doesn't have to be alot. Now take off the exhaust pipe and spray carb cleaner in it till it runs out the bottom pretty good. Blow it out with a air hose if you can. Now that your sure you have the right mix drain the carb bowl again, get it started and go for a 10 mile run. Should be ok then. I'm betting the exhaust is goo'd up esp if you have a catalytic converter one.
Put something FUN between your legs..
