Thread: My project(s)
Old 06-17-2009, 07:30 PM
TheOtherStyle's Avatar
TheOtherStyle TheOtherStyle is offline
Default Re: My project(s)
Ok, I was thinking about it, and now I'm wondering this:
HarborFreight 2.5HP 4stroke. 79.5cc, 3600rpm max.
centrifugal clutch with 10t gear
80t sprocket on the rear wheel.
This would come to a 38.8mph top speed. Given that tires vary, and the circumference will be a little different at the outside edge of different tires, this would translate into a top speed of 37-38.8. Not much a variance, but I thought I would note it.
My question, to Forbisher, is do you think thes HF 2.5hp would pull hard enough from stop with a centrifugal to run the above setup? Or should I consider an even lower (numerically higher) wheel sprocket? Top speed is not my priority, I just want a good solid and strong setup.
