Some Help ; )
DonnnN
Hey, I Got A 70cc Chinese Engine.. Need Some Help With Wiring.. Cause My Kit Didn't Come With A Installation Manual..
Ok, The Black Wire From The Engine To The Black Wire On CDI.
Blue Wire From Engine To Blue Wire On CDI
What About The Kill Switch? It Has Two Wires Black And Yellow.. Where Does The Black And Yellow Wire Connect To?
Maybe this will help too.
Don,
Ground means to the frame of the bike or Motor (unless your motor is insulated from the bike somehow the whole frame of the bike is ground). I used the water bottle holder screw. basicall what happens when you press the switch is that you short out the power which would go to the ignition (no more spark)
Hope that helps.
