Old 04-24-2008, 07:23 PM
Mopedamauter79's Avatar
Mopedamauter79 Mopedamauter79 is offline
Default Re: Bicycle Motor Refuses to start
Originally Posted by Bikeguy Joe View Post
I think you've found the solution in your first post.
yeah. The oil is leaking from the exhaust I replaced the gasket. I will get around eventually to mailing it. For the key It is possible the vibrations from the engine knocked the key loose enough that the magneto picked up from pure magation..
It was vibration more the normal and my exhaust tip had came off. I had tightened everything up after and well it just sat as I was waiting for a new exhaust. Sense then it hasn't worked..
I will try to get the key back in place properly and try again..If it still don't work then I officially give up and I will take it apart and mail it.
