Old 06-05-2009, 11:25 AM
Airbuzz Airbuzz is offline
Default Re: Spring-loaded chain tensioner
Thanks Junster. I cut one shim last night from some .250 thick aluminum, and plan on cutting a couple more from .050 thick aluminum tonight. The shims will match the foot print of the mount. No washers will be used as shims for me. I may put a layer of thin hose rubber in between the shims as a bit of a damper. That mount has to be firm.
