Old 04-18-2008, 09:35 AM
bgoates's Avatar
bgoates bgoates is offline
Default Re: Motor Refuses to start
Are you having the same problem I did, ie you have spark when the plug is out and no compression. But with the plug is in and with compression your clutch is too loose to turn the motor over. Are you hearing the motor turn over when you pop the clutch? It should almost sound like it is running. All I had to do was tighten the clutch.
