Old 05-02-2009, 10:53 PM
skinnydog1_2007's Avatar
skinnydog1_2007 skinnydog1_2007 is offline
Default Re: crank arms spinning with sbp jack shaft kit
huckersteve thank you for the reply. Yes i did use the bottom bracket crank spindle that came with my sbp kit. As my bike was an 2008 model the bearings looked good. I did not know what type of grade grease i was meant to use so i used car bearing grease. I hope this is not to thick a grade of grease to use and now my bearings have deceased because of this. Still have to have a look an see what the problem is.
