Old 04-27-2009, 01:44 PM
Cabinfever1977's Avatar
Default Re: Centrifugal clutch kit cover clearance
my stock one that came with my engine rubs on the cover(cover did have a couple of dings)but anyway i tried to wack and sand the bumps out but clutch still rubbed so i made a second gasket out of thick cardboard,i think it worked i dont here the scraping noise no more,but its hard to tell with the other noises that come from the clutch area and the engine. it does run good. you dont have to stack gaskets just make one thicker one out of rubber or something. i did stack two ,but i'll replace with one when i can.
i wouldnt do anything to the clutch pads or plate when a simple thick gasket will fix it.
