Old 04-13-2008, 07:15 AM
Mopedamauter79's Avatar
Mopedamauter79 Mopedamauter79 is offline
Default Re: Motor Refuses to start
Originally Posted by VENICE BOY View Post
If it WAS running good, with this carb... check to see if the jet or inlet needle are clogged!
Take the float bowl off.. the jet is the long brass tube screwed into the carb housing. make sure there's no dirt clogging up that tiny hole!
Blast everything with carb cleaner!
Also put on a in-line fuel filter.
The needle is brand new. I didn't even have to proper one before. I do now. The entire carb is clean.
