paul
is their someway to make the chain tighter like a single link available? i am using the chain tensioner but have to have it all the way up for it to keep the chain snug. i tried to remove another link but then it was to short by just a pinch. my thoughts are the straighter the line from the sprocket to the engine the better it will be.
Cruiser, one thing you may try is to add a master link to the regular bicycle chain which will allow you to move the wheel back, allowing you some adjustment on the motor chain. Also you can try to adjust the location of the tensioner, closer to back wheel or closer to the motor. I had the same problem on my chain.
