Old 04-09-2009, 12:30 PM
Cabinfever1977's Avatar
Default Re: New build gasket questions
i am using the stock gaskets,i only replace them if there bad or easy to get to,but the only one i see i need to replace is the pull start(left cover,theres a gap even with the gasket,theres no gas or oil in there,but i dont want my electronics to get wet,i have tape around the gap but will seal gasket with gasket i use gasketmaker or teflon tape on gastank petcock,carb to intake,throttle to intake.but if you want to replace stuff on the engine,its better to do it before you put gas in it and run it,because it will be more messier if you wait til after.
