Old 04-09-2009, 11:43 AM
Wheel Rush Wheel Rush is offline
Default Re: Compression after 9 Months
It starts up every time but it passes the point where it started up with a fairly fast pedal and I could practically coast while engaging the clutch, and it started, . . now I have to pedal at that point and after the clutch is engaged I still have to pedal against the compression, and after a few revolutions of the pedal it starts kicking slowly and starts.
I am thinking you might have something there with the lean mixture, not sure about air leaks.
Whats the story there ? If I recall spraying around sealed joints with carb cleaner or what?
Would you change the mixture to something a little richer ?
