Old 04-03-2009, 07:13 PM
commander's Avatar
commander commander is offline
Default Re: Clutch problem(s)
I made the mistake of greasing the gears in there once and I had similar results you are having. If you recently did this then use some brake clean and remove all grease from your clutch area and reassemble and give that a try .hope this helps
