Old 03-31-2009, 02:19 AM
AndyT AndyT is offline
Default Re: Building a 2004 Yeti DH-9 with 40cc Tanaka
I spoke to GEBE today and asked a few questions. They said it was important to maintain the 14.5 " (I thnk) dimension from the axle to the top of the mounting strap. If you bent and drilled, you most likely changed that dimension, unless you measured and were careful. This may cause a tension problem on the belt.
Also does that motorcycle rim have the same number of spoke as the drive ring you bought with your kit? If not it won't snap in place.
A call to GEBE should get you straightened out. They seem very cool.
