Old 01-17-2008, 12:11 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: cross engine question
Thank you Norman.
I figured someone would have a piece of it around. Now I either have to get a smaller toothed sprocket for the rear wheel or a larger sprocket to weld to the the sprocket already on the motor.
I'll have to check around to find a small one compatible with the chain and rear sprocket from the kit. I can pick up the rear sprocket and chain on ebay pretty cheap I think.
I wonder if the number twenty five chain would fit on a mountain bike large sprocket. That might be interesting as well. I have a mt bike I bought for parts that I think I could resurect somehow. You know, run two chains on it. One from the electric motor and one from the crank set to a smaller gear. I wonder what that would do ... does anybody know. That shouldn't be much different from the gas setup with two chains.
I guess it would since it would make the pedals turn with the electric engine that could be dangerous.
