Old 03-21-2009, 06:25 PM
Shadeslay's Avatar
Shadeslay Shadeslay is offline
Default Re: Chain Length/Tension Question
You can also adjust the tensioner by sliding it back towards the wheel dropouts. I had to keep mine way back towards the wheel dropouts, because no matter how tight I tightened the wheel of the tensioner it would always slide to the bottom, so to fix that problem I kept the tensioner wheel in the bottom position and slide the tensioner towards the wheel dropouts.
Edit: truthfully you are likely better off keeping the wheel of the tensioner as low as possible. Less chance of it pulling into the spokes.
Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself.
