Old 03-07-2009, 02:46 PM
tyrslider's Avatar
Default Re: Motor running faithfully now, but.......
The sure fire way to check your carb settings is to do throttle chops. You'll need a couple new plugs. 1st 1/8 throttle is not adj on these carbs (would be idle air screw), though less airflow restriction is essentially an adj. of this and all carb phases. 1/8-3/4 throttle is needle, and 3/4-WOT it is main jet only.
So run your bike under load in the range your experiencing problems in for a 1/3-1/2 mile then hit the kill switch. pull the plug and check the color. Should be light tan. Brown = rich, white = lean.
Pushing the plunger down floods your carb and acts like a choke, you want some air in your float bowl. If pushing your plunger down helps then your fuel level in the carb is too low.
FireBelly Cycles and MachineWorks (lol)
Motorized Bicycles, Parts, Tools and Accessories for the Real World!
