Old 08-09-2016, 10:20 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Clutch not engaging, clutch flower nut spinning and loose
Simple to replace, simple remove gears and knock out from either side. Protect new shaft when installing and use a penny to lock the gears for tightening, and use large screwdriver or vise grips to hold pegs in center of clutch for that side
