Old 08-04-2016, 03:36 PM
johnsoma's Avatar
johnsoma johnsoma is offline
Default Clutch not engaging, clutch flower nut spinning and loose
Can anyone help? My clutch wont engage. I take the cover off to tighten the flower nut and it wont get tight, it just spins and spins when I attempt to tighten it. When I have it at its tightest it moves in and out on the threads of the rod it is supposed to tighten ontu. Is it stripped? Is this common? How dow I fix this? JUst get a new flower nut?
Also how do you pull that whole assembly apart in there? Where the clutch arm pushes the bar, the small sprocket is attached, the clutch is on the other side with the flower nut and all, that axle thru there, how do you get it all out and rebuild it? Is it pressed in?
